how do i clear
5 replies · 1,777 views · Started 30 March 2004
ive just purchased a nokia 6600 2nd hand but brand spanking new. my mate had it for 2 days and only messed about on it before decidin he didnt like it.
anyway hes set up things like blurtooth and his bluetooth name etc.
how can i clear all this information and reset it all so i have to set up everything ?
thanks in advance.
basically get rid of anything he may of done as return it to a state is if i was getting it out of the box brand new first time.
so i dont have to format the phone or anything?
can you recomend any apps,symbian bits or stuff i should purchase for the phone?
Thanks.
You will have to know the security code to restore orig fact settings. if its not been changed it will be 12345. try the shop here (the tab next to the forum one)
