Share PC's internet connection with SX1
4 replies · 8,881 views · Started 31 March 2004
is it possible to Share PC's internet connection with SX1?
like in 3650 and 7650 i mean.
If yes... how?
Try the same procedure as for the 3650/7650 with the dummy access point.Search the forums and let us know if it works.
source: http://groups.yahoo.com/group/sx1_siemens
written by: moderator
Internet over Bluetooth
This guide is to show you how to use your PCs internet connection
for your SX1 over Bluetooth. What do you need?
- a PC with internet connection (preferably DSL)
- a Bluetooth dongle
- SX1
The Bluetooth dongle should off course be installed and configured
on your pc. In addition the Siemens Data Suite should be installed
together with mRouter software (contained in Data Suite).
In the device you should create a new accesspoint. For this, go to
setup -> settings -> connection -> access points. Then choose
options -> new access point -> use default settings. Then you should
copy the following settings. You shouldn't need to have to change
much.
Connection name: arbitrarily e.g. Blue DSL
Data bearer: GPRS
Access point name: None
User name: None
Prompt password: No
Password: (nothing)
Authentication: secure
Gateway IP address: 0.0.0.0
Your PC should be connected to the internet. Now you create a serial
Bluetooth connection between your PC and your Mobile. In your
Systemtray the mRouter symbol should look like in the picture: Now
your connection is ready for use.
Note: If you should have to problems with the Bluetooth connection,
first enable the Bluetooth connection and then start the internet
connection.
I'm pretty sure this doesn't work at all 😞 Have been trying using opera.
I have a serial port established with the phone (paired) and my bluetooth icon in the system tray is green.
My gprs icon still comes on when I connect using the dummy connection. it even still allows me to continue browsing web pages after I pull the BT adapter out of the pc.
I do have a real gprs connection setup on the phone, and somehow I think it reverts to using this even though I haven't selected it anywhere.
Hi members,
Does this work ?
My main question : Do I need to have credits for this?
I did all steps ( create a dummy access point and did the serial connection between pc and my sx1.
Can I have others access point in the mobile or just the dummy one? And Do I have to do any associantion with this dummy access point?
Please help me.
Chilli.
_Xerox_ wrote:source: http://groups.yahoo.com/group/sx1_siemens
- SX1
much.
Data bearer: GPRS
User name: None
Prompt password: No
Password: (nothing)
connection.
