Daylight saving time problems
0 replies · 5,760 views · Started 31 March 2004
Hi all,
I'm syncing my P900 with my Windows 2000 machine at work. The P900 doesn't get the DST right. My settings are such that I want my P900 to sync time and date each time it connects to my PC, as it has an NTP-set, accurate clock.
If I uncheck the "Europe" box in the clock settings of the P900, the clock on the P900 is set to one hour less than the time of my windows box, and the "Europe" box is checked.
If I check the "Europe" box, the clock on the P900 is also set to one hour less than the PC clock. The box is left-as-is.
The above behaviour is independant of what time my P900 clock is set to. So I always end up with the time being set to PC time -1 hour and the "Europe" checkbox being checked.
Does anyone observe the same behaviour?
I'm using the German, latest (2.3.1) version of SE's sync software for Windows.
Thanks for your help
Andreas Weder
