Avec Radio
13 replies · 4,000 views · Started 31 March 2004
Has anyone tried using avec radio over the GPRS? i had downloaded the trial but unable to get it running cos it only allow 1 try. I was not connected to the internet when i started it but when i finally started the connection, the trial is already over!!
does it work in Singapore?
is it work the price?
I've never tried that, but i did buy a radio handsfree off ebay, which is a normal hands free, with a radio built in.
cuddlers89: What radio handsfree did you buy? And is it compatible with the 6600? I mean... does it do all it should do as in play radio, stop playing radio when you're receiving a call and restart afterwards?
Please specify a make and model. Thanks! 😃
It
  • Is compatable with nokia 6600
  • It stops the radio when i get a call and continues afterwards
  • Has two volume settings
  • Has two headphones
  • Has a clip which attaches to the 6600 to go around your neck so it doesn't get lost or stolen
  • Has lovely flashing lights when you get a call, these are not powerd by the battery it uses the radiation generated from your phone
I doesn't say a make, on the front it says radio handsfree, andi've lost the box.
Thanks for providing all this information.
Ebay, here I come 😃. Well, at least to browse since no one ships to Romania.
If you don't find one, i could sell you mine as i don't use it very often. I'll post it to romania aswell. Private message me if you are intrested.
cuddlers89 wrote:If you don't find one, i could sell you mine as i don't use it very often. I'll post it to romania aswell. Private message me if you are intrested.
do u have the pic how does the headset look like? i am interested but the thing is that i don't know the item is sold in singapore or not :P
shchiam1978 wrote:do u have the pic how does the headset look like? i am interested but the thing is that i don't know the item is sold in singapore or not :P
If you look on the sellers feedback, up near the top somewhere, it will say their actuall location.
cuddler, r u located in singapore? if u r then can meetup or call u to find out more on the headset.
If you look at the top right of his post you will see his location is good old blighty. 😊
@Cuddlers89 so are you saying that just d/l the 'avec radio' software is not enough for listening to the radio on the 6600 you need some hardware as well?
I've been trying to get this thing to work for a few days now with no success, could you or anybody else who as used this proggy explain just how you get to listen to the radio? I've got GPRS, what i'm I doing wrong? :? :?
You do not need hardware to run Avec Radio. It is a software that utilises the Internet via GPRS (= $$$$$). It runs using real player format. Until now I am unable to use avec radio altho I can update the preloaded links. It just would not stream the radio. However, if I copy the rstp:// address onto a computer I can get streaming. Seemed that it does not run on 6600 :icon13:
