Is there any possible way or hack to use the Bluetooth Headset with the radio? It seems that this should somehow be possible. I hate using anything with wires so I was wondering if there's a solution.
Bluetooth Headset w/ Radio?
The radio uses your hands free wire as an ariel so you need to have it plugged in to recive signals. If you have the handsfree plugged in at the same time as the bluetooth headset is activated it might work, but that would mean you would have two hands free things on. If this doesn't work try plugging in only one of the connectors.
Personally i cant see the point, i prefer to listen to music etc. throguht two headphones and in stereo.
Until Nokia or whoever else release a bluetooth stereo headset i cant see the point in trying meself.
SAbz
I know the music won't be ideal...but I just hate not even having the option to listen to music/radio with the Bluetooth headset without that thing plugged in. It seems inhibiting.
Sometimes it would even be nice to listen to a sports broadcast, where stereo isn't that important.
