Installed MSVC++ 6, sp5.
Downloaded sdk 1.0 (ages and ages ago).
When I compile hello world (for both phone and emulator) it doesn't show the menu bar (or associated panes when pressing the hotkeys).
I hate getting stuck at the HelloWorld stage 😞
Check that you have set correct rect settings for your container.
Thanks Fuse,
I used the Hello World supplied with the sdk, (both v0.9 and v1.0) and have not modified the code, so those settings _should_ be correct else I'd be a very unhappy camper.
Any other ideas?
