help deleting inbox message
3 replies · 1,798 views · Started 01 April 2004
hello guys,
yesterday, i have beamed via IR from laptop to my 6600 an agilemessenger installer. I had received it then on my inbox as a IR device message. But after installing it, I cant delete it. It says "General:Already in Use". I had even restarted the phone and problem is imminent. hope you guys could help me out. :redface: tnx
Try using your file explorer to browse your mail folder you will find this in
C/E-System-Mail. you should be able to delete it from there
freedom wrote:Try using your file explorer to browse your mail folder you will find this in
I've tried psiloc's latest manager, FExplorer (great program), and Wisend.
When I get to E-System-Mail it's a ton of crazy folders
I'm in exactly the same situation as the first poster. I sent myself a file
Called: Bluetooth sjs1.jpg
I can't delete it. and I can't open it
it just stays.
The only thing I can think is it keeps trying to be opened by a handler, but since it's 16mil colors (oopsed) it errors...but I figured it would just be downconverted or ignored.
help please
Ok...fixed that. Renamed Memory Card to Memory Card (someone will mention this bug) then did it from my card reader. Found the filename and deleted the 'unix' filetype w/ the same code (I think it's the mbox mapper). I'm not sure, but I think I started having problems on my 6600 after installing autolock (I'm guessing it runs a thread for timing that's not 'nice' since I couldn't back up to memory when it was installed). Anyone else get the same problems? If it was that easy to detect 'last kaction' from a 6600 someone would have modified torch to add a timer...guess it's time to look at the symbian dev forums. Backups are so nice.
