Can't Remove Symbians Installed
1 replies · 2,424 views · Started 02 April 2004
i installed some .sis games and now i cant remove them.
i checked apps. manager but they are not in it they are only in the log.
I also downloaded and installed two other games and i can find them anywhere on the nokia 3650, again they are in the log has installed but they are no where else and i can't get to remove them. 😡
Strange?!Well,try using a file manager like FExplorer and delete the applications from c: or e:\system\apps.Be carefu, you might do serious damage with a file manager.
