are there any progs to change more colour option for palette other the blue green and purple ????
and
do you think the joystick is strong to hold around 1.5 years
and
My first post!! Muhahahahahha!!! 😃
There is a program to change the colour palette, Active Desk by Cibinex. You can get it here: http://www.allabouter6.com/software/directory/viewsoft.php?id=22
I think the Sony Ericsson T68i's joystick got loose pretty fast, but it is loose by nature! So far my joystick in the 7650 is the same as it is, (as all seven-six-five-oh users i cant put it down!) it depends on how ya use it, and its waaaay better than the joystick on the T68i, cause you feel the quality moving the Nokia's joystick 😃[/code]
Hi
i have d/l the active software i like it but i got this problem.
when it is at "home", under calendar it says "1 meeting today". when i go to the "calendar" page, my appointed is at later date which i hv fixed in advance. i have check out my system date and active desktop date and timing is tally. what went wrong?
hrmm what other colours would you really use but?
how do you get palette colours to change with a.d? :roll:
about the joystick.
i have had/have both phones and took them both apart, the joystick unit of the t68 is only 5*5mm the one on the nokia are actualy 5 buttons (like the snake joystick) but than put together in a case whit the size of 1,2*1,2cm much better i think
any small prog to add only additional color pallete to the phone? active cybernetix prog is too big ...
ANyone considered or tried to replace the balck joystick tip on the 7650 with a red one from IBM laptops/mice?
For those who hahe taken their phones apart, do you think they will fit?
Just like the colour and feel of the IBM tips.
