6600 USB Data Cable, any software?
8 replies · 5,253 views · Started 02 April 2004
[FONT=Arial Black]I bought a 6600 data cable from a seller online (Not from Nokia),wondering if there is any software or pc suite for it? Please help if anyone know. 😊[/FONT]
No. You probably should've bought a good Bluetooth adapter/dongle for your PC instead.
N/A wrote:No. You probably should've bought a good Bluetooth adapter/dongle for your PC instead.
But why do other people sell it? There should be a software online somewhere isn't it? Just like data cable for 7210, T610 software can be downloaded online, just couldn't find any for 6600.
elton wrote:Where does it plug into the phone then?????????????
6600 data cables act almost the same as 3650. It is plug in at the battery slot. Battery are then plug on the data cable to power up the phone.
The pc suit for 6600 comes whith an annoying box in the tray called connection manager. that has an option to connect using a serial port
Won't help. That piece of software is shared with other phones that support cable connectivity. The 6600 PC Suite and the 6600 itself with PC Suite only works when using infrared (IrDA) or Bluetooth.
Supreme001 wrote:[FONT=Arial Black]I bought a 6600 data cable from a seller online (Not from Nokia),wondering if there is any software or pc suite for it? Please help if anyone know. 😊[/FONT]
Hi i sell cables for these phones online, if you like go to : epocware.com and you can download file manager which is a great program and works with all symbian phones, i my self use it with my p800 as i prefer that over the priginal software.
ANy more info email me : [email][email protected][/email]
have fun guys.
ciao
