ETI Camcorder for 3650?
11 replies · 4,521 views · Started 03 April 2004
Anyone knows if ETI Camcorder for N3650 WORKS OK ???Any bugs?Does it record for unlimited time or does it stops after a while? (Cause in N6600 doesn't work...)
works fine on 3650.
Thou I prefer phillips camcorder pro.
Same features but makes .3gp videos which are easily played back on the PC or mobile.
ETI vids need to be converted first..
will
Anyone knows if phillips camcorder pro works on N6600 as well??From where can i purchase it?
:frown:
This question has been answered more then once in the 6600 forum.The answer is no.Use the search feature.
Just a quick one Ghosty, you closed a thread involving requesting own made videos because of 'illegal content'
But will has links in his sig to 'over18' Oplayo material. 😊
Sure, but NOTHING illegal, just some adult fun.
I put over 18 as I don't want to offend anyone who may download it..
willbrady wrote:Sure, but NOTHING illegal, just some adult fun.
the software phillips camcorder pro states that it works on the nokia 6600
so why is everyone saying now that it doesnt, and why would it work on an inferior device like the 7650 and not the 6600
thanks
Well,in some cases,like the stability of the OS,the 6600 is inferior.The 6600 runs on a different updated version of the OS and UI which is not compatible with many applications released for the older OS and UI version.Search the forum.
Haris wrote:Anyone knows if ETI Camcorder for N3650 WORKS OK ???Any bugs?Does it record for unlimited time or does it stops after a while? (Cause in N6600 doesn't work...)
