hI,
ive got a SERIOUS problem with my 6600,
it does not start up, it lights up with a 15 sec white screen, and then turns it selfs off. It tried with charger but nothing. Is it the battey? or what?
cheers
hI,
cheers
If you do a search you will find many possible solutions to your problem.
willbrady wrote:If you do a search you will find many possible solutions to your problem.
You were very enlightening..... 😊 :tongue:
Try a safe mode start-up and then if it doen't work...Bad luck. I had to replace mine with the same issue... 😡
willbrady was right.Recycling topics is not exactly usefull,thread closed.
