hello there everyone - i`ve got some questions for ya`ll 😊
1. I only have money for 3650 at the moment - and will propably need about 5 months to gather all the money for a 3660. Should i buy the 3650 or wait another 5 months and buy a 3660 ?
2. Is there another difference besides the 65k display of the 3660 ?
3. Is it a big difference between 4096 and 65k for that little display ?
4. Can i buy a 3650 and install a 65k display on it ?
5. Can i use 3660 software on 3650 ?
thanks alot in advance,
mike
1. Up to you.
2. Keypad layout is the main thing.
3. Not enough to matter (in my opinion).
4. No.
5. Yes (or vice versa).
Just buy an 3650 if you're not botherd with the keypad. Its not worth to wait an extra 5 months for a phone thats is practicly the same.
El_Cidd wrote:hello there everyone - i`ve got some questions for ya`ll 😊1. I only have money for 3650 at the moment - and will propably need about 5 months to gather all the money for a 3660. Should i buy the 3650 or wait another 5 months and buy a 3660 ?
mike
get the 3660
Keypad is not the only difference.
The 3660 has a tft screen (mutch more colours than the 3650)
I don't think the the screen is worth wating six months.Like N/A said,the difference between the screens is not that great.
Personally I don't think it's a biggie between the 4k screen and the 65k screen. The only biggie is the keypad in fact. If you really ain't bothered about the keypad, the N3650's a good choice indeed.
Yes get the 3650 then just buy a 128 MMC or 256 MMC later on. That would be the better option. Just re orient yourself with the keypad, if ur an avid nokia user, it would take some practice to like, learn how to text again, but in the meantime, just boast about your 256 MMC or something. :tongue:
