issues with Philips Camcoder
3 replies · 3,031 views · Started 04 April 2004
don't know if someone faced the same problem, but as I was using the philips camcoder happily, I isntalled several softwares to try, and now I can't get the camcoder to work, as I can't figure out what are the applications that caused that to happen.
I tried uninstalling and installing it back but didn't work!
as when it launches, I can see the camera box for a second then it shuts down with a program error: "Reason code KERN-EXEC, Reason number 3"
anyone, any idea?
thanks to somone at Esato who gave me the answer, so if someone else got this problem, here it is:
if that happened after installing CadidCam then you only have to uninstall Ecam and then reinstall Philips Camcoder, and it'll work fine!
