GoBoy
2 replies · 3,218 views · Started 04 April 2004
Problems with Goboy
I got some problems with goboy. When I transfer the files with bluetooth to my cellphone, they come automatically in my inbox. I move them with SeleQ to the GoBoy folder and an errormessage appears. You're about to delete system-files, so I click cancel. The *.gb file is in the folder and I open it with GoBoy but nothing happens, what's the problem? :frown:
When the error message appear that you are about to delete system file,press ok.It's because u cut that file from your inbox into other folder,so when you copied that file,it will prompt you to delete the previous file from inbox.Do you understand?
Asakura wrote:Hi,
Thnx it worked 😊
