Phone Memory
7 replies · 2,052 views · Started 04 April 2004
Hi to all,
I was wondering i had saved all my programs to the mmc but my phone memory (not ram) gets lesser.
When i check what takes up the space on my phone memory, there nothing much.
Is there any way to get a highe rmemory, preferably full.
Thks.. 😃
Check your pictures taken, could be he problem?? Transfer them to your MMC. Could help saving some memory on your phone 😊
estepona wrote:Check your pictures taken, could be he problem?? Transfer them to your MMC. Could help saving some memory on your phone 😊
Thks 4 ur reply but i du have any pic, video clip or songs in my phone memory...
As above. A lot of apps/games also use c:\ (phone mem) to store additional config & data files. If you browse to c:\system\apps you'll see most of them there. Also if a program that generates temp files (while running) crashes then that temp file will remain there in phone mem. Quickword is one such program that works this way, it can't seem to handle large documents without crashing and leaving a temp file in phone mem.
Just use FExplorer or similar to browse through the phone mem. 6mb isn't much to check so it won't take long.
Its just comn pbm gal try with the latest fileman or just opt cc (Carbon porting) or software flashing
I was toying with my new N6600 with fexplorer and found that altho you may have deleted the sms, some still stays in the mail folder of the phone mem. I had transfer pgm via IR to my N6600 and having installed the pgm, i deleted them from inbox. But when I go thru the mail folder, I still see the pgm inside.
I just delete these off.
BTW can anyone explain why there are so many folders in the mail folders which are empty. Can we just delete these off?
Is there somewhere where I can read about the file structure of series 60?
