I just installed ReadM 1.11 into the MMC and have the following question:
1. I cannot find the library folder in the MMC or the phone memory. Where is it?
2. After saving my txt files from the inbox, where does the txt files go to? The ReadM can only detect the files if the setting is set to all others. I also cannot find the files anywhere. (In 7650, I can find the files)
3. I cannot transfer the txt files to the library directory of ReadM. It gives an error message "cannot move the book". Why?
Thanks!
To update on what I have discovered:
the txt files are in mail folder of the phone mem altho the original sms from inbox had been deleted. I do not remember the txt files to be "stored" in such files with 7650.
In the process I also discover files that I have already deleted from inbox still present in the mail folders. Read other thread concerning phone mem
I answer my own question again! Nothing wrong with ReadM just the wrong version (for 7650) :redface: that cannot creat library folder on MMC. Updated to version 2.03. Voila! problem solved! 😃
