alright.. thanks for the reply! ive got an ultra mp3 player... but i dont think
my nokia 6600 can take the very big size of mp3.. though ive got
nokia converter which can convert mp3 to wav sound but i still cannot
listen the full song!
i would like to request that will someone tell me how to short down
or compress the mp3 file to easily play on my mp3 player?
regards,
frs.
Do a search please mate, this subject has been discussed time and time again.
Search for bdpoweramp and compress using the 'phone' template.
Will
try to download an mp3 to wav coverter then download the latest audiograbber program and it would convert it to at max half the size with the same quality.
frs112211 wrote:alright.. thanks for the reply! ive got an ultra mp3 player... but i dont think
or compress the mp3 file to easily play on my mp3 player? regards,
frs.
Joy RingTone Converter - Save any part of your favorite mp3s to MMF, AMR, MIDI ringtone
Website: http://www.joyringtone.com
Joy RingTone Converter enables you to create your own ringtones by converting your MP3, WAVE files and CD tracks to the most common Ringtone format, including MMF, AMR, MP3, MIDI, WIDI, WAV, AAC, 3GPand MP4. The contained CD Ripper extracts digital audio CD tracks to audio formats WAV and MP3 with excellent output quality and high ripping speed, and [SIZE="2"]the MP3 Compressor can reduce the MP3 file size up to 30%-70%, save valuable space on your Mobile Phone.[/SIZE]
There's also a batch conversion function for converting MP3 or WAV files to RingTones automatically!
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
