Does anyone have any problem with the Multimedia Converter supplied with the CD-ROM that comes with the 9290? I open the file and try to convert ANYTHING, even the sample music files that come with windows XP, and the program crashes. Nokia's highly tech minded answer to my half-hour-on-hold question was that it must be my computer rejecting the software LOL I told them I noticed on the forums a lot of people seem to have the same problem. Is there any other conversion software out there? I'm thinking maybe an XP issue or something?
I appreciate any info anyone has. Thanks.
Wirelessly posted (Nokia6600/1.0 (3.42.1) SymbianOS/7.0s Series60/2.0 Profile/MIDP-2.0 Configuration/CLDC-1.0)
Use the nokia web site ford latest version. I will recommend you the pro version 😉
