Sync Calender
2 replies · 1,711 views · Started 07 April 2004
Nubie needs help, any ideas on syncing palm calender with nokia 6600 calender??
Sorry, forum search came up empty...
Hi mate
AFAIK, the only conduits in place for synchronisation are for Outlook, Lotus Notes and Lotus Organiser - are you running any of these apps? If so, sync your palm calender with whatever you're using and then sync that with your phone.
I'm afraid I have no idea if you're not using any of the above.
Cheers
Kav
I have a Palm as well and I uses my PC as an interface to download calendar infos. I don't know any other way,
Cheers 🙄
