:frown: Stupid question: How do I input a space in number mode? What about decimal point?
How to input space in number mode
:tongue:
There's no such thing as a stupid question - keeping quiet is stupid 😉
The space is on the same key as the zero which works with predictive text switched 'on' or 'off' - just press the key once.
Pressing the '1' key gives you a full stop in either mode.
Cheers
Kav
:icon13: Nope! In number mode, press 1 key gives 1 and not decimal point and press 0 key does not give space but 0 :?
In number mode, if you want to enter a space, you have to press the "+*" key and select it from the symbol table, unless you want to switch to text mode with a long press of the "#" (and then back to number mode after you've entered the space with the "0" key).
