will contacts be erased after formatting?
i deleted some c:\system files, now phone is going nuts!
cannot retrieve emails anymore despite setting up the mailbox!
i want to format phone. but afraid contacts will be erased.
anyone can advise me?
thanks
btw, my pc died and prob need reformatting too...
pc suite did back up my phone b4...
but i am afraid all data gone after pc reformat...
now cant even boot up to windows safe mode...
damn
Yes, contacts will erased after format 😞
puffler wrote:Yes, contacts will erased after format 😞
thanks!!!
damn...
how am i going to get my 500+ contacts back on the phone??? :?
i have no pc at home now to backup using pc suite!
my pc died!!!
now on public terminal to post threads...
ARgh!!!!!!!!!!!!!!!!!!! 😡
help!!!!!!
set you mailbox to the MMC
Select all your contats and e-mail them to yourself.
Go to your outbox and save the e-mail to drafts.
Reformat Phone.
Go to the e-mail in drafts, open it up and open the attachments and you can then 'save business card' and put the contacts back.
Best
Will
or you can try backup contacts to MMC using internal backup command on phone: Extra - Memory - Options - Backup to MMC. I think, this is solution 😊
Yes, but, when he backs up he will be backing up a screwed phone - once he has reformated,if he restores, he will be restoring the screwed version back into his phone...
Will
Or he could try backing up his contacts.cdb 😃
I remember I once read on a guy's how he backed up and restored his P800 or P900 contacts.cdb
He did it using FExplorer... connected to his mobile and he would push reset in the software and then cancel the reset as this would remove the lock on contacts.cdb.
Then copy contacts.cdb to his computer and do the same after a format to write it back.
