Masks plugins for Photographer
7 replies · 2,886 views · Started 07 April 2004
Well i have uploaded masks plugins for Photographer 2.4 (from the openbit site) to my N6600 (uploaded to MMC=>others), but when i open the Photographer prog. i don't find them inside...Do i have to upload them smwhere else?What do i do wrong?
:frown:
Did you install them from the sis file - it will put them in the right place.
Make sure you have the NEW version of 2.4 of a couple of weeks ago as masks don't install properly on the old 2.4 that came out a couple of months ago.
If you want to do it manually you can put them in the 'masks' folder either on phone or MMC depends on where you installed photographer and rename the first field of the filename to 'masks' and they will appear with the other masks on your phone.
If you want them in their own submenu within photographer then you'll need to install them from the sis file as a .dll is required which is bundled in the sis.
Best
Will
willbrady wrote:Did you install them from the sis file - it will put them in the right place.
Best
Will
Thanks man, but maybe i have the old 2.4 version of Photographer. Where can i find the new one? 😎
willbrady wrote:on Handango or www.openbit.com or visit the wapsite from within photographer on the phone.
Also get the new plugin too, just to be sure 😊
I 've downloaded the version from openbit and i have installed the masks plugins, but still won't play.. :frown: The first time i installed both (before my upgrade with firmware 4.09.1), they used to play ok (Open bit Photographer has 30 day limitation). Now that i installed them again (after my upgrade), i have only 2-3 masks (the others won't play). Is it cause of that?
What are the limitations of trial *.sis files? Do they work only for 1 month?
:icon14:
Why not drop openbit an e-mail, they have always been very receptive to me in the past.
I'm sure they will be helpful 😊
Not sure what the trial limitations are, was ages ago I ran the trial version.
Will
Best
Will
