Hey there!!!
I need help. My ngage restarts...At firs I tought it was the battery. I changed it, and it happend again.
I don't know what's the problem. Then I tought it was something wrong with the mmc...No, it's fine.
My phone just turns off and then it turns itself on again, then off, then on again, then off, then on again...
I'm going crazy here, please help me...
And one more thing...I've formated the mmc, but now I have nothing on it and my stupid ngage says that it's corrupted.
How do I fix it?
Help me, please. It's a matter of life and death...
PLEASE HELP!!!
Help Please
First things first. BAck up your phone if you have anything important on it. Then format the phone. Type *#7370# and type the security code in. 12345. Make sure you have a charger plugged into the phone whilst formating it. If this doesnt solve your problem, then its most likely a software error, in which case your best off taking it to a NSC to get it flashed and hopefully a software upgrade if there is one. Hope this helps.
SAbz
SAbz911 wrote:First things first. BAck up your phone if you have anything important on it. Then format the phone. Type *#7370# and type the security code in. 12345. Make sure you have a charger plugged into the phone whilst formating it. If this doesnt solve your problem, then its most likely a software error, in which case your best off taking it to a NSC to get it flashed and hopefully a software upgrade if there is one. Hope this helps.SAbz
THANX
