could any one please tell me how to FORMAT the communicator 9210 NOT THE MMC, thanks a lot bye
about formating the 9210
Wirelessly posted (Nokia6600/1.0 (3.42.1) SymbianOS/7.0s Series60/2.0 Profile/MIDP-2.0 Configuration/CLDC-1.0)
Restart the phone and when shaking hands appear on screen press shift+ctrl. !Please backup your data like contacts and calendar first. And if you will use search you will find out more 😊 including how to obtain more free memory on 9210 😊 keep us informed how and what you did 😊
Nearly Special Boy!!
Disconnect battery, hold Shift & CRTL, replace battery, the screen goes white then bright white, now press the "f" key.
The same process can be used with "i", but this will delete the INI config files. This will kill any personal settings to the device. Including the e-mail & internet settings.
I have a lot more on 9210/i. So if you have any more questions?
thanks a lot guys but dows the communicator say that it is formating or what??
and again thank you
A message will be displayed on the screen asking "about to format unit" or "about to delete INI files" you can then use the screen buttons to accept or cancel.
I install a font file to my communicator and when reboot it, it is flickered give the white screen then go in black then again return to the white screen then ...etc.
how can i format my system?
WHen formatting if I were to format it ( German version) and install the downloaded ENglish software SIS ENG or what ever it is would that convert the display language to English?
If that does not work how can I accomplish this?
This can be done only @ nokia service centre. Might cost up to 50 eur. 😊
