hi
i have been using the theme editor for sometime now but i cannot figure out how do i get good quality screenshots of the theme............the screenshots that i have of my themes make my themes look miserable...is there a technique to get thos attractive screenshots......somebody please help!!!!!!
you could upload it to your phone and then use SeleQ for a screenshot.. or make a print screen paste it in photoshop and cut it out.. that's what i do most !! 😃
i too use the print screen but the quality is very very very pathetic............have u seen the other themes like the ones at mango?? they look so good feel like buying them at any cost............
any suggestion on how to achieve that quality??
First one question: did you make them with the symbian 60 theme builder on your pc? Then it is simple just go to the checkout option, there will pop up an other window that shows your theme in different positions. Then press: CTRL+PRINT SCREEN (its next to the F12 button). Then go to PAINT and just press CTRL+V to paste the image into PAINT. If you save it as an BITMAP file there will be no quality lost!
Well thats all! 😃
Srry for the confusing english but i'm from THE NETHERLANDS! :icon14: :icon14: :icon14:
Well good luck i hope you understand it!
HI! ..
Using the SeleQ File Manager App you can make screenshots
at any momment on your own phone once you installed the theme on it...
There you can choose either JPG or BMP format for that image captured... so not
quality lost (if use bmp)
cya!
There is also a small app called S60 Screen Taker which does the same job.
