hi! can you guys help me..
i deleted some of my themes from 'themes' and it was ok, but when i delete some again , suddenly the themes was changed to my original themes. when i go back the themes menu, the themes that i placed there are gone. i was trying to delete them from the app manager but it said that the file is corrupted. i tried to install it again but it said 'unable to read file'
please help!! how do i delete all the themes i installed and how to make it work again..
thanks very much!!!
please help!!! urgent
You should've uninstalled your themes from the manager.
You still have what are known as 'trash files' on your phone.
Download the trial of AppMan from www.symbianware.com
Install it.
Start it up.
Go to the last tab on the right ('Installed Applications'😉
Go through your application list and delete all trash files (they have a small trash can icon next to them).
Hope this works for you.
Thanks a lot! yeah stupid me! i didn't delete it from the manager.. 😊 but i already deleted the files using the file explorer.. but i still can't install it, i tried installing it using my phone memory and it worked! 😃 but what about my memory card? is there a chance where i can still use it for my themes? thanks a lot. im downloading the appman already. i'll try it now! Thanks!!!
