Alarm Clock Problem in 3660
2 replies · 3,779 views · Started 08 April 2004
Dear All Genius There
I already sent one PM to the GHOSTDOG but no reply seems he is too busy.
So I am here for your help.
I encountered a unique problem in my 3660. When you set Alarm clock in any profile, or when phone is silent or if you switched of the phone after setting alarm, it works fine It gets activated on time and start buzzing (start the Alarm sound).
But when you select the profile MEETING it only beeps one and the screen starts blinking, no buzzing or Alarm sounds.
But when you activate Meeting profile and switch the phone OFF & Switch it ON again it works fine, but when you go back to any other profile & come back again to Meeting Profile the same problem persist.
Can any of you gusy help me as I went to Nokia care but of no use.
Thank you
I would think that the reason it only beeps once in meeting is because, if you were in a meeting you wouldn't want to inturupt everyone with lots of loud bleeping. Although i tried on my 6600 and the alarm went off the same on meeting, silent and general.
Dear Cuddler
I didnt get you. You meant to say you are also facing the same problem? This is happening only in one profile which is editable. That also when you selct that profile after selecting another profile. I mentioned before also when switched the phone OFF and switch it on again the Alarm sound correctly. But when yous elect any other profile and go back to Meeting profile the same thing happens means you get silence Alarm
