i need an answer from expert ngager
2 replies · 1,955 views · Started 08 April 2004
ok i have nokia multimedia converter 2.0 and i liked it and it worked great for me until some point last week when it messed up and now the audio will end up being like 5 seconds ahead of the video, even when i put it on its default settings it still messes up. i uninstalled it and reinstalled it and it stillwork, it just doesnt make sense and it's pissing me off sabz, ghostdog, any other experts i missed, you got anything?
Sometimes the lag can be caused by the video source.. my suggestion would be to use TMPGENC or a similar program to convert the original video to another format or even the same as the original format and then try enconding it through the Multimeidia 2.0 thingo.. but having said that using Helix will give you a much higher quality video at around the same size if you follow sabs's tutorial
