sound files
3 replies · 2,228 views · Started 15 September 2002
Hi guys 😊
I have a question to ask: How can I transfer wav or midi files from my pc to my 7650?
(I have installed IR support to my pc)
many thanks!
Make sure the PC and phone are speaking over your Irda link, then in windows explorer, pick your wav or midi file and right click... select "send file" and send it to "IR recipient". The file should then appear on the phone as an MMS message in your inbox. From there you can save the sound file to the phone and delete the MMS. The file will appear with the standard ringtones and will also be listed under "extras" "recorder".
You don't need to start the PC suite at all.
S.
No problem !! 😃
It's not actually an operation that's very well documented in the official literature, they kind of assume people know how to transfer files.
*edit* It took me a few attempts and looking at forums before I got it to work too.
S.
