Repeating Calender enteries
2 replies · 1,692 views · Started 08 April 2004
Hi all, how do i enter something into calender and have this repeated on the same day every month or have a 4 week gap?
When you add a calander entry just scroll the the bottom of the screen there you will find the repeat options.
If you tick weekly you can the select the interval.
I notices that the monthly option does not always work to well.
I have tried monthly by day (wanted something that would be last sat every month but does works more on the closet date. So feb sometimes messes that up.)
But every 4 weeks should work well.
KayonLord wrote:When you add a calander entry just scroll the the bottom of the screen there you will find the repeat options.
ah yes works like a treat, thanks!
