Backup and Restore Import Function
1 replies · 5,840 views · Started 09 April 2004
I had a P900 backup *.ecs file and since I reformatted my PC i want to import it and restore it to my phone. Problem is after I import, it doesnt appear on the backup and restore menu. I cannot access the restore function because I cannot see the files to restore.. HELP! MT LIFE DEPENDS ON THIS 😞 All my data everything 😞 This is happening to me because of..
http://www.allaboutsymbian.com/forum//forum/thread/21479/
DARNIT!!
I need to restore my jotter , datemate, calendar, CONTACTS and all the folders, etc...
Wait I think I solved it. You see, what I did before improting the old back up was relocate the directory to the dierectory I configured my backups to be saved on, do hope you guys get that. ( In backup and Restore you can customize the place where your backups can be stored thats why.) So what I did was link it the directory where my backup was and then import the backup from there. That seemed to be the problem since the file I imported was in the same directory as where I want to improt it, it wouldnt appear.
So what I did to solve the problem, create a new directory, Link the backup and restore directory to that directory, then import and file which was located on my old directory.
Well I do hope you get what I mean 😊 And I hope this helps all you others also! 😊
This still doesnt solve my problem on the other thread though which how mrouter connectes and the others functions wont please refer to the other thread for that.
