Hi all, I'm intending to buy a P900 but before, I just wanna make sure it will really fulfill my expectations :
1- I use VPN and a secur Id card to connect to my professional mail server and download e-mails. Would that be possible with a P900??
2- Is the hand writing function really working??
Great Thanx
Download Lotus Notes e-mails on P900
YJA wrote:Hi all, I'm intending to buy a P900 but before, I just wanna make sure it will really fulfill my expectations :
Great Thanx
1) I also need to use RSA's SecurID card but thus far have not been able to find the appropriate information that tells me what the SecurID fields on the P900 relate to on the card. I tried all sorts of combo's but nothing has so far worked.
I am not sure you can have an email account on the P900 use SecurID but you should be able to browse webmail/corporate intranets via SecurID.
2) Yes it's really working.
Bateman
Bateman wrote:1) I also need to use RSA's SecurID card but thus far have not been able to find the appropriate information that tells me what the SecurID fields on the P900 relate to on the card. I tried all sorts of combo's but nothing has so far worked.I am not sure you can have an email account on the P900 use SecurID but you should be able to browse webmail/corporate intranets via SecurID.
Bateman
Hi, I was browsing over the P900 user guide and found that it is normally supposed to handle RSA's SecurId card connections (page161 English version).
They say P900 can automatically generate these secured Tokens, so basically you don't really have to capture anything.
