Debug problem under CodeWarrior
2 replies · 1,774 views · Started 09 April 2004
Hi all.
There is a simple question for those who debug applications on WinsCW target emulator.
How (in the debug session) can i see on Emulator screen the result of any step in my source code?
I mean that after pressing Debug, the common UIQ Emulator screen with all active applications appeared. But after i set breakpoint anywhere in my code and run my Application from Emulator GUI, the marked breakpoint is reached, but after that i cannot see the Emulator screen at all - only the source code and other Windows in CodeWarrior! I see the Emulator's minimized picture in the task bar, but can't maximized it!
Can anybody help?
Thanks for anyone in advance.
Max.
So, as i see, nobody uses CodeWarrior in development for P900 device? Really so? Or i should put a question in a different thread?
There is yet another problem with CodeWarrior: on-device debugging.
For i couldn't start with step-by-step debugging on the Emulator, i tried to launch THUMB UDEB on-device debugging session. But after all settings were made accoring to documentation ("Symc_C1_SymbianCppOnDeviceDebugging_V2.1"😉, the connection with MetroTRK failed.
[My P900 is connected through USB-cable to PC's COM3]
Can anybody help for this problem at least?
Thanks for any help in advance.
Max.
Check that you have selected COM3 in MetroTrk setting.
View-><Project Name> Thumb UDEB Settings ->Remote Download
