KamaSutra NOT SUPPORTED FIX?
6 replies · 2,118 views · Started 09 April 2004
Hi all i installed KamaSutra for the p800 on my P900 and im getting a Not Supported message, i was wondering is there was anyway of getting this to work on the p900 or am i the only one who is having this problem?
This app is writen in VB so you need to have app forge boster installed.
Not to sure if this is your problem but only thing i can think of off hand.
KayonLord wrote:This app is writen in VB so you need to have app forge boster installed.
Got app forge booster installed, ive emailed them, maybe they a newer version will work on P900
hi,
just try them. and its not support, you are right.
its say need visial basic.
i did try them before, its wont working
so nothing i do.
try ask contact who from you download from them.
good luck.
i may find out, will let you know.
cheers
Dunko9 wrote:hi,
so nothing i do.
good luck.
cheers
Thanks for trying mate :icon14:
