Image memory
3 replies · 1,502 views · Started 09 April 2004
I'm using about 20M of a 64M memory card to store downloaded hi-definition jpgs. When I try to zoom in beyond 50%, I get the following message:
:icon4: Images: Memory full. Close some applications and try again.
I don't have any other apps running.
:? Any thoughts/suggestions?
I've tried everything I could find on the board to free up RAM, including *#7370#, but even then I get the same message. :frown:
It only seems to happen with JPEGs over (roughly) 130Kb.
There is nothing you can do to increase the amount of RAM to a 3650.
Unless you upgrade to a 6600 or 7610!!
