Global Zoom Setting
5 replies · 2,587 views · Started 10 April 2004
Hello there, I'm new here, and I hope this isn't covered before; I searched around but I couldn't find anything related to this.
My question is, is there a way to set the zoom for all the applications with 1 setting? A control panel option or maybe a program? I find it very troublesome to have to run every single application to change the zoom setting individually.
My P900 is flashed to the latest revision (R4A04) by the way.
hey, there is an app. its called photofusion ,from scalado.com, you can zoom 4 times with it and its got some other settings/prferences.
if you are interrested ,email me at [email][removed][/email] for a crack.
mrky wrote:hey, there is an app. its called photofusion ,from scalado.com, you can zoom 4 times with it and its got some other settings/prferences.
First of all cracks are not allowed here, second of all, I don't think that's what he meant. I think he means the zoom level of the text in all apps, not the camera.
To answer SanXP's question I'm afraid it's not possible. You have to set the zoom-level at every app seperately
I believe when you've done so for each application or screen, then you won't have to do it again!
so spend some time with it once ...
i need to set for the zoom level everytime i turn on my device for the speed dial zoom level
i think it's kinda a bug or something not quite sure though....
