Help?.............
2 replies · 1,093 views · Started 10 April 2004
Hi
say if you send something to your 6600 via bluetooth say with a P900 the 6600 saves it in messages. Is there anyway to send it to your memory card without a file viewing program like seleQ??
thanks in advanced..... 😉
"Help?............." isn't exactly a very descriptive subject title, you know. Next time try to use something more meaningful.
The phone software is designed to save incoming Bluetooth or infrared file transfers to the Inbox. But you can in Messaging app settings switch the memory in use from phone memory to memory card.
If you are sending via Ir, you can move the file to any folder you wanted (inc memory card)
First off go into File Manager > Go to the folder where you want the file to end up > Select options > Receive Via Ir. Now when you send the file from another device it will apear in the folder you selected.
Genius!
