When playing bounce I get enouph rings to goto the next level!!! But I can not get to the next level. Has anyone any idea how to get there? What button do I need to press??? What am I doing wrong??? 😮ops: 😮ops: 😮ops:
Bounce???? Help???
go to the red laser door thingy
btw how to activate the sound for bounce ??
i tried both audio off and audio on but there is no difference
Thanks but where is the red lazer door thingy???? 😮ops: 😮ops: Still embaressed that I can't work this out 😮ops: 😮ops:
usually near the last circle that you past through
if u don't pass through all the circle the door is just like a steel door but when you pass the requirement the door become like red laser door
btw do you hear any sound from bounce while you were playing it ?????
Yes and it is bloody loud.. have had to turn the sound off!! Have to admit when I first played the game there was no sound, but then realised that I had the silent profile activated 😮ops: 😮ops: 😮ops:. Do you not get any sound then when you are playing the games?? Do check your profile setting as this does have an effect 😃
wow thanks that''s cool i turn off the warning tones in my profile and there was no sound but after i turn on the warning tones i heard the sound
but yeah the sound is very loud better turn off the sound heheh
My pleasure 😃 . Still have a problem though, have been through all the rings on level 1 but the door at the end is still a blue steal colour :-? now getting very annoyed :evil: :evil:
in lvl 1 there are 5 circle and the door at the top lvl
btw have you jumped from the blue colored floor cos the door is up there
or maybe something wrong with the game
just tried the game lvl 1 now and it's ok heheh
genius 😮 found it. Cheers. 😃 😃
can anyone post a pic of bounce
I sorta want to install it but I dunno the description just doesnt sound that great and I cant find any pics of it.
Here it is. It's fun, if loud 😃
it is actually very very good fun !
quite adictive actually !
i think the game kinda like Sonic cos you just jump and pass through rings
but yes the game is good and there's only one think i worried about which is my battery cos it drains my battery sometimes
Now that I have finally got it to work, I can't put it down. Very addictive 😃
Sweet as
now that I have an idea what its like I think ill actually install it 😊
I can not complete this damm level. I have all but the last ring, near the exit door. The last ring is suspended and there is a floor where you should jump to then get the last loop, but the floor is protected by thorns. Under the floor is a moving surface. I can not get enough height to reach the floor under the ring.
Now I have noticed a "device" which is bricked in, not far from this area, which I can not get to. Is this device something to do with the solution, if so how do I get to it? How can I get the extra umph to reach the last loop?
I have been stuck here for a week!!!!
Many thanks in advance
Victor
[quote="VictorJWood"]I can not complete this damm level. I have all but the last ring, near the exit door. The last ring is suspended and there is a floor where you should jump to then get the last loop, but the floor is protected by thorns. Under the floor is a moving surface. I can not get enough height to reach the floor under the ring.
Victor[/quote]
I was stuck on this bit for weeks and weeks, there really is no special way to do it, get on the far left of the ledge sticking out of the wall and just go for it (You can get a small run up), it's all about timing.
Your near the end of the game now, and beleive me it gets alot harder.
Thanks, Tried it and done it. 😊 Any idea about the bricked in thingy? Its just a bit before you drop down to the moving floor area.
[quote="VictorJWood"]Thanks, Tried it and done it. 😊 Any idea about the bricked in thingy? Its just a bit before you drop down to the moving floor area.[/quote]
I completed it months ago, and haven't used it since, I can't remember which bit you are talking about :-?
Maybe post a screeshot so it will jog peoples memory.
Make shure you download the level pack from Nokia web site
