Outlook Putting Space on my contact numbers?
3 replies · 2,807 views · Started 11 April 2004
I was sure there was a thread about this somewhere but I cant seem to find it. Does Outlook 2003 still auto adjust the numbers by putting space between the area codes? This was abug that caused the P900 not to display the sent names on the sentbox of the P900. Is this still a problem even with the latest software?
Hmm I tested it now,used a contact and intentionally placed a space on the name and sent him an SMS and after the message was sent, I checked the sent box and his name was there so this is already fixed.
BUT, I have experienced problems when sending multiple SMS or MMS, when some numbers have a space between the country code and some have not the P900 will not send the messages or you will be given an error, but after adjusting all the numbers by taking away the space they became ok. Weird huh?
Yes this problems was just a P900 bug bit it got solved already -) But Like I said, sometimes I have a hard time sending messages, I get erors and when I fix the spaces they get sent ok, both sms ans mms.
