Hi
this is strange. have u come across
but THE MISSED call shows 30 mts less to actuall missed call time.
even thou the actuall time is corret 😡
Missed call TIME is wrong
its a bug...
set ur GMT offset to 00:00, Call time problem will be solved!
vickyee wrote:Hi
Thanx
but why is it the GMT keeps changing AUTOMATICALLY.
and do we have a FIX for this bug.
the GMT changes probably because you have day light savings set to: "on" i had this problem as well when i fixed that problem was solved. if you still get wrong times on miss call probably someone is calling you from a diiferent time zone 😊 or your phone is a dud 😊
