any change of changing the icon when u create a new folder ?
Folder Icons
'fraid not.
thanks muchly for the responce, and is there anyway of creating a folder within a folder
You can't. The menu folders are not really file system folders (where you can nest folders deeper). They're just made to look like they are, and they're fixed to two levels.
There must be some way. In the end, the folder image is an image as well...
