Ringers and stuff
1 replies · 1,283 views · Started 12 April 2004
:? :? ok i want to know if you can erase the midi files that came from factory setting on the n-gage, i use the fexplorer and i can see the file path for most of the stuff but i try to erese the files and i couldnt so:
i wanna know if you can and how?
whats the path?
where you have to erese them from?
and i also want to know if you can store personal files (like short MP3 files) on the same directory where the midi files were stored so you dont use memory from your memory card to put ringers
thanks a lot
i hope you can answer my cuestion :?
The built-in tones are in Read-Only Memory (ROM) - drive Z. In other words, you can't delete them.
Writable storage memory in the phone is on drive C. Tones in C:\Nokia\Sounds
The memory card (MMC) is drive E.
