Msn Status for Nokia Series 60
1 replies · 5,193 views · Started 12 April 2004
You can check MSN status through MSN status checker. It will show you if any contact is online or offline. By using MSN status checker you will also know if your friend blocked you or not. Simply enter email address of your friend bellow, and press Check Status button.
