BlueTooth File Transer....only one way?
2 replies · 1,518 views · Started 12 April 2004
Do any of you find it strange (or aggravating) that the P900 will not send files to a bluetooth enabled device, e.g. a laptop? I have a Siemens SX1, and with it I can send pictures I have taken to my PC for processing via BlueTooth, which is a great feature. I have not been able to find this feature on my P900; from what I can see, it can only "receive" files. For as much as this phone costs, don't you all think that this would be a feature that is essential...2 way file transfer?
Does anyone know if this is planned for a future OS upgrade?
Thanks,
elfer
:frown:
I'm not sure if I get your point right, but you can send any file via BT, if you want to send a picture, select it and then click Pictures ==> Send as ==> Bluetooth.
That should do the trick! :tongue:
You can use the filemanager to send other files. Hope that helped. :icon14:
WOW
you made my day!
I had never before found that menu setting.
Now I tried it and worked just fine!
Thanks so much 😊
elfer
