I have paired my Jabra Bt200 with my SE P900 and my also my PC. I dont know if this is the reason but now I cant use voice dial anymore on my Jabra. When I press the answer button of the jabra nothing happens on my phone anymore, before what happens was I hear a beep then a second tone represents the phone asking me the voice dial already. Is there a way to unpair everything or clear the paired items on the headset?
I had not problems with this before, I have the latest firmware on my P900.
As far as I can remember (I don't have the manual with me to check) you can only pair one device at a time with the BT200. Also, if it is currently paired with the P900, make sure that voice dialing is enabled in the Voice Control section of the control panel. When you unpair a device, it seems to reset all of these settings next time you pair them. Which is a bit of a pain to put it mildly.
Re-paired them and it solved the problem Is there a way to use magic word and make it connect to the headset when it makes a call?
what I noticed:
I think Because I paired the Jabra and Phone first then the Jabra and PC, it automatically set the PC as primary device thats why voice dial wouldnt work.
@bassey, it works fine with my PC and my phone, its just that whichever device you paired it first with gets to use the bt200's answer button function first.
eg:
If you paried PC first then P900, when you press the answer button of BT200 it creates a connection with PC. But when a call comes in your P900 you can still use your BT200, of course this doesnt work if headset is currently connected with PC.
If you paired P900 first then the PC, when you press the answer button of BT200 it intiates voice dialing on P900 but you can still use your Headset as the headset of your PC.
