Hello again! I have a client that really need a printer to his 9210. I�m almost sure that I once saw one of these but cant remember where. Does anyone know what I�m talking about or does someone have another solution?
//Akn78
//Akn78
Nokia don't do one, but there are a few portable inkjet printers that'll work with the 9210. Canon do a couple: the BJC 55 & BJC 85 both work with it, & you can get NiCad batteries if you need to print without a power socket (their predecessors, the BJC 50 & 80 work too: I have an BJC 80 & am very happy with it). Or if portability is at a premium, you might want to look at the Citizen PN60i: it's really tiny, but pricey. OTOH, if your associate isn't bothered about portability, a bunch of the HP Deskjet/Laserjet laser printers have a plug-in IR port as an option. Check out the available printer drivers for the 9210 - that'll probably give you a few ideas.
or maybe you may want to check out "extended printers" by psint.
check out their website at www.psiloc.com
www.pentaxtech.com
Lastly, the Psion infrared printer adapter gives you a wide range of printers to print to, including the HP LaserJets. That is what I chose after some research.
Roger
I got the Deskjet 350 from PC World. It works for me ok but you can either have a black cartidge installed or the colour. Not both at the same time. The batteries last for ages when printing just text. I think it was �189.
[quote="Nemopics"]I got the Deskjet 350 from PC World. It works for me ok but you can either have a black cartidge installed or the colour. Not both at the same time. The batteries last for ages when printing just text. I think it was �189.[/quote]I have been unable to print to an hp Deskjet 350 via infrared from a 9210i. I keep getting an error message saying 'Printer not responding. Check that it is turned on and connected'. Can anyone help me please? :cry:
I print on HP Laserjet 2100 without any problems 😊
HP Laserjet 5P (built in IR port - work great with 9210)
Anyone knows where I could find BJC-55 driver for 9210? Or any idea how to get 9210 to print via irda to BJC-55?
i'm using HP 990cxi professional, built in irda, it's working fine wit my 9210i.. but it doesn't prtint colors.. :roll:
