i�ve a problem.
there is a error message "memory full"
it was not possible to run any aplication and now its not possible to start the phone
only some error messages "memory full", "not enough memory...." ....
has someone else this problem?
What to do??
thanks
... this was discussed some days before ... search the forum. Here in Austria I would go to the next Nokia Service Center and get the phone resetted in one hour.
the only way????
after resetting in nokia shops the data is lost!
This is a bug.
But he is not existing in all devices.
he is not fixed from Nokia in this time.
(i hope nokia know it even already!)
NEVER let more less then 150-100kb on your phone-memory.
(even this is dangerous,cause maybe someone send u in this moment some sms/mms,and the shit happens...
Use your Pc-memory,
make each Day a sync,
put the "noneed" fotos out.
i always get 2mb free.
so i can also use the Cam 4 real,if the party is on highnoon 8)
i never had a problem with sync each day.
Only ones i full up my memory 4 selftest:
(2month ahead,if i dont know already about it)
I also use at this time a early version of Task-man.from psiLOC.
so i also open 19 apps,and then i start 2 shout out fotos,until it was full.
Then i saw 3 time a error-message,start 2 be nervous,und open(tha hell,i didnt wanna do it!!)
the Tm.
now popup a system-kernel-error,that i have 10!!times to put Ok.
but then,it was NO reboot,so i cut remove the fotos first,then close all apps.
and make a reboot...
The 7650 had no probs with it:
but now,i know it better,and would never do this again :roll:
so,u can see,this bug must not kill your device:
but he can!!!
hope 2 help u....
GreetZ from swiss
S�mi
its nothing possible!
not possible to start the photos to delete one.....
yeah,this is bad...
only way 2 get out:
go 2 your NSC,and let make from them a new SW-update.
(if they wanna send in:
first be friendly,and say no,and explain them:that this is not yuor fault:
if this not helps,
start 2 speak small bit more loud about the cash u spend and that you will not accept at all.
so,they will react more friendly.(cause they can do 2 nothing else,first its your right,and seccond:
it would be not a good PR for the other clients in the store)
hope this help
S�mi
nahh that's what i called a good idea 😃 😃
ah I thought I was just being stupid keeping like 2mb - 2.5mb free, do you all do that
wonder how long I can do that for, I dont have a connection to my PC so it makes it hard.
i�ve updated the soft in a Nokia shop but is still not starting....
only way is to swap the phone!
...to all
backup your memory !!!
if that was the case eddie did they do it under warranty or did you have to make an insurance claim ?
