MP3 audio
4 replies · 1,889 views · Started 13 April 2004
Hi.
What audio format can we play using the real one player, i have some audio files which are in .amr format will these work. Please help
The Realone Player in the 6600 will not play *.MP3 you would need a 3rd party *.MP3 player installed on your device for that.
Realone Player supports *.wav, *.amr, *.rm &*.3gp.
There also might be a few others. But cannot find the page on RealNetworks site.
badger wrote:The Realone Player in the 6600 will not play *.MP3 you would need a 3rd party *.MP3 player installed on your device for that.
I converted MP3 into .amr using the nokia multimedia converter then I sent these files to the real one player, but they sort of crashed meaning it doesnt work straight away, we have to close the real one player a couple of times, whats this problem. I also downloaded the helix producer, whats the way to convert MP3 files to .amr or .rm files using the helix producer, your help is very much appreciated.
Using Nokia Multimedia Converter should work fine. What settings are you using?
Just send the files to your phone and save them somewhere. Then open Real Player and Open Saved Clip.
Helix Producer is better for Movies. Search the forum for more info on that.
