Sco connections for audio applications
1 replies · 1,270 views · Started 14 April 2004
Hi everyone
In short our application need to open a SCO connection between a Serie 60 phone and a bluetooth headset to transmit audio data.
The Serie 60 SDK allow application to open ACL connection like L2CAP and RFCOMM. The HCI command KHCIAddSCOConnIoctl return a THCIConnHandle in a THCIAddSCOConnectionBuf but there is no way in the SDK to use this value to send data in the SCO connection. How can we use this handle to send data in a SCO connection ? Is it possible to get acces to low SymbianOS System Call that manage this kind of connection ?
Hope someone has the answer,
Thansk in advance
Pierre
Hello
I have nearly the same problem as you have. Your post is from april, then maybe you have found a solution ?
I hope you will help me in this.
Thanks in advance
Best regards,
Jerome
